FBCMoyock
Apr 16, 2020Tutor
SFP ports don't work after firmware update
After upgrading the firmware from 1.0.4.16 to 1.0.5.12 my SFP ports no longer work. I am using RJ45 SFP adapters that were working perfectly prior to the update. I have also tried version 1.0.5.22 wi...
- Aug 12, 2020
I switched to genuine Netgear adapers and everything is working fine
schumaku
Apr 17, 2020Guru - Experienced User
Hm, more a GC510P or GC510PP? I would not write here without my GC510PP SFP ports in workable condition 8-)
The v1.0.5.12 (same for the GC110, GC110P, GC510P and GC510PP) is more than one year old - not sure why you upload such an dated version - as per the records Netgear pushed these and newer versions on Insight over the last 12 or 13 months. In local management, you could consider to upload GC110 / GC110P / GC510P / GC510PP Firmware Version 1.0.5.25 to the same Flash section (not to loose 1.0.4.16).
FBCMoyock
Apr 17, 2020Tutor
I did try the latest 1.0.5.25. That's where I first noticed the problem. I went from 4.16 to 5.25. Down graded to 1.0.4.16 and they work, decided to start with .15 and see if it would work. It didn't so I didn't see a need to go back to .25 until I checked to see if this was an issue anyone else had.
