FBCMoyock
Apr 16, 2020Tutor
SFP ports don't work after firmware update
After upgrading the firmware from 1.0.4.16 to 1.0.5.12 my SFP ports no longer work. I am using RJ45 SFP adapters that were working perfectly prior to the update. I have also tried version 1.0.5.22 wi...
- Aug 12, 2020
I switched to genuine Netgear adapers and everything is working fine
SloppyJoe
Apr 28, 2020Aspirant
I have the same problem. My sfp modules are working with 1.0.4.16 but not with 1.0.5.27, extremely annoying.
After the upgrade the sfp link goes up and down allt the time. It kind of works for a second or two but then the link goes down. Happy for any suggestions on how to fix this!
- FBCMoyockApr 28, 2020Tutor
I am now on the latest firmware and no change. I was using 3rd party adapters. I took a chance and bought a Netgear brand AGM734 and it is working. I have ordered a 2nd for the other port. Not sure why my generics stopped working after the upgrade though.
- SloppyJoeApr 28, 2020Aspirant
Ok, thanks for the info. I'm using ubiquiti UF-RJ45-1G modules. It may then be that they are incompatible with later firmware than .4.16.
- schumakuApr 28, 2020Guru - Experienced User
Interesting, we're operating no-name Cisco-ID flashed 1G SFP RJ45 modules - absolutely flawless on 1.0.5.27.
- NetworkGBAug 12, 2020Aspirant
This is happen to me too , I have this version : 1.0.5.27 ( GC110 )
I have bought 10GTek SFP To RJ45 and This not working to me , How could I fix that ?
Thanks.
- schumakuAug 12, 2020Guru - Experienced User
NetworkGB wrote:1.0.5.27 ( GC110 )
10GTek SFP To RJ45
Provide exact designation if this SFP module please, e.g. ASF-10G-T, ASF-GE-T, ...
- NetworkGBAug 13, 2020Aspirant
10GTek SFP To RJ45
I have bought This :
https://www.amazon.com/dp/B01FRQJ1Y2
"1.25G SFP-T, 1000BASE-T Copper SFP, SFP to RJ45 SFP, Compatible with Netgear AGM734"
I would appreciate if you could help me please solve the problem.
Thanks.
- FBCMoyockAug 12, 2020Tutor
