FBCMoyock
Apr 16, 2020Tutor
SFP ports don't work after firmware update
After upgrading the firmware from 1.0.4.16 to 1.0.5.12 my SFP ports no longer work. I am using RJ45 SFP adapters that were working perfectly prior to the update. I have also tried version 1.0.5.22 wi...
- Aug 12, 2020
I switched to genuine Netgear adapers and everything is working fine
SloppyJoe
Apr 28, 2020Aspirant
I have the same problem. My sfp modules are working with 1.0.4.16 but not with 1.0.5.27, extremely annoying.
After the upgrade the sfp link goes up and down allt the time. It kind of works for a second or two but then the link goes down. Happy for any suggestions on how to fix this!
NetworkGB
Aug 12, 2020Aspirant
This is happen to me too , I have this version : 1.0.5.27 ( GC110 )
I have bought 10GTek SFP To RJ45 and This not working to me , How could I fix that ?
Thanks.
- schumakuAug 12, 2020Guru - Experienced User
NetworkGB wrote:1.0.5.27 ( GC110 )
10GTek SFP To RJ45
Provide exact designation if this SFP module please, e.g. ASF-10G-T, ASF-GE-T, ...
- NetworkGBAug 13, 2020Aspirant
10GTek SFP To RJ45
I have bought This :
https://www.amazon.com/dp/B01FRQJ1Y2
"1.25G SFP-T, 1000BASE-T Copper SFP, SFP to RJ45 SFP, Compatible with Netgear AGM734"
I would appreciate if you could help me please solve the problem.
Thanks.
- EdEpiphAug 16, 2020Aspirant
Having the same issue. Installed two QSFPTEK QT-SFP-M modules Netgear and the link goes up and down. Confirmed the laptop NIC works using one of the first 8 ports on the switch.
Any updates?
- FBCMoyockAug 12, 2020Tutor
