FBCMoyock
Apr 16, 2020Tutor
SFP ports don't work after firmware update
After upgrading the firmware from 1.0.4.16 to 1.0.5.12 my SFP ports no longer work. I am using RJ45 SFP adapters that were working perfectly prior to the update. I have also tried version 1.0.5.22 wi...
- Aug 12, 2020
I switched to genuine Netgear adapers and everything is working fine
NetworkGB
Aug 12, 2020Aspirant
This is happen to me too , I have this version : 1.0.5.27 ( GC110 )
I have bought 10GTek SFP To RJ45 and This not working to me , How could I fix that ?
Thanks.
schumaku
Aug 12, 2020Guru - Experienced User
NetworkGB wrote:1.0.5.27 ( GC110 )
10GTek SFP To RJ45
Provide exact designation if this SFP module please, e.g. ASF-10G-T, ASF-GE-T, ...
- NetworkGBAug 13, 2020Aspirant
10GTek SFP To RJ45
I have bought This :
https://www.amazon.com/dp/B01FRQJ1Y2
"1.25G SFP-T, 1000BASE-T Copper SFP, SFP to RJ45 SFP, Compatible with Netgear AGM734"
I would appreciate if you could help me please solve the problem.
Thanks.
- EdEpiphAug 16, 2020Aspirant
Having the same issue. Installed two QSFPTEK QT-SFP-M modules Netgear and the link goes up and down. Confirmed the laptop NIC works using one of the first 8 ports on the switch.
Any updates?
