Picmention
Apr 29, 2017Star
SFP+ RJ45
Hello, I don't know if this is the right forum, but I wanted to buy a Synology DS2015xs NAS with two SFP+ Ports. I found the Netgear ProSAFE AGM734 1x 1000Base-T Modul. I did't worked until now wi...
- Apr 30, 2017
Hi Picmention,
As far as I know, the AGM734 is compatible with the SFP+ interfaces of XSM7224S as well as with the SFP interfaces of GSM7328FS. About the compatibility with the Synology DS2015xs NAS, it may or may not work.
Kindly check this link I found online and it might help. Also, its best that you ask assistance from Synology about your concern.
DaneA
NETGEAR Community Team
DaneA
Apr 30, 2017NETGEAR Employee Retired
Hi Picmention,
DaneA
