NAM-CONCEPT
Mar 20, 2019Tutor
sfp+ s3300 to server
is it possible t ouplink the switch to the server via sfp+ and fibre directly from the switch??
- Mar 20, 2019
If compatibility (read: vendor ID) is enforced, this is a thing you have to ensure between the server/SFP+ network interface, or even the network interface card and the server. Consult with Dell for the requirements or the "generic" network equipment, for compatibility with the network card itself, for the SFP+ side makers/suppliers which can offer SFP+ modules programmed accordingly.
Be aware that there are some servers require special OEM versions of NIC cards which might look similar, even have the same PCIe slot size. And there are cards in the free market witch are special OEM versions for one or the other server brand (and model) - this could be a special config for the PCI lanes, this could be a special programmed vendor ID again.
schumaku
Mar 20, 2019Guru - Experienced User
Sure, just ensure the port is not configured as a stacking port. Beyond, both peers must be SFP+ and 10 GbE.
- NAM-CONCEPTMar 20, 2019Tutor
thank you ... that sounds logical, but we also think that our dell server doesnt like our interl based sfp+ module, and in its drivers section it say unidentifed nics controller... so I am kind of hopeful that by getting 2 new compatible sfp+ transceivers it will all get resolved quite quickly!!!
Unless I am very wrong?
R
- schumakuMar 20, 2019Guru - Experienced User
it all makes sense.
I have already asked dell to provide us with 2 compatible trasceivers, for the server card...
our switches have been stacked for years with sfp+ trasceivers AFL SFP+-31-10GE-10-C-D, sfp+ 10Gbase-LP 1310nm
I can only assume that if we get our dell fitted with recommended SFP+ modules, then switches should be able to retain old SFP+ parts?
