Mantariz
Dec 14, 2013Follower
Smart Control Center V1.1.3.1 not settings adapter.
Hi,
Hoping someone can point me in the right direction.
I just installed Smart Control Center to version 1.1.3.1, It does not keep the network adapter setting. Thus it is so far pointless.
I've tried setting and applying the network adapter, the application then advises it needs to restart to apply the setting, and closes.
When I reopen the application, no adapter is set. "No Active Network Adapter"
It is getting quite frustrating. Any assistance appreciated.
Running Windows 7 SP1, with latest updates.
Sorry for digging up an old thread, didnt notice until after I posted.
Incase anyone else runs into this problem and finds this thread, I was able to fix the problem, by right clicking on the Smart Control Center program and running as administrator. Then it is able save the adapter change properly.
Thanks
Chris
- faceprofileAspirantSame problem on GS516 TP :(
- chammondPMLITInitiate
Same problem, it defaults to the wrong adapter in my system and it cant find any switches. I go to the adapter tab change to the right adapter and hit apply. The program says it needs to restart, I hit ok, it reopens with the wrong adapter again.
The program is worthless to me right now.....
Is there an ETA on a fix for this problem?
I am running Windows 10 64bit Pro with v1.1.3.2 of the smart control center
Thanks
Chris
Thanks
Chris
