juergenbgrusa's avatar
Dec 20, 2022
SNMP GS728TPPV2
Hello all,
I would like to add GS728TPPV2 Switches into SNMP Monitoring. Unfortunately I did only find at System > SNMP > Supported MIBS
BRIDGE-MIB
ENTITY-MIB
EtherLike-MIB
IF-MIB
P-BRIDGE-MIB
Q-BRIDGE-MIB
RFC1213-MIB
RFC-1215
RMON-MIB
SNMP-COMMUNITY-MIB
SNMP-NOTIFICATION-MIB
SNMP-TARGET-MIB
SNMP-USER-BASED-SM-MIB
SNMPv2-MIB
SNMP-VIEW-BASED-ACM-MIB
POWER-ETHERNET-MIB
My Question here is since Atera RMM Tool is requesting the OID. Where can I obtain the OID?
Thank you Juergen
    • juergenbgrusa's avatar
      juergenbgrusa
      Hello Schumaku, thank you very much for your reply. I already found this download resource. But the download is just a buch of .txt files. I'am not that confident how to implement them since RMM Software is asking for OID.
      Thank you Jürgen
      • schumaku's avatar
        schumaku
        These are the management MIB required. The OID is the starting point for MIB queries used by such tools. The start OID is typically referenced on the Web UI. All switches start at the similar point in the oid tree. if in doubt, start with .1.  8-)
ProSupport for Business
