Cryptage
Mar 20, 2022Tutor
SNMP port speed bug on GS308T 1.0.5.5 firmware
Hello everybody,
I think there's something's wrong with SNMP on 1.0.5.5 firmware for GS308T switches.
I check ports speed and value is always "1000000000" , even if the port is down.
For example, only port 8 is up on my switch but :
With MIB :
IF-MIB::ifSpeed.1 = Gauge32: 1000000000
IF-MIB::ifSpeed.2 = Gauge32: 1000000000
IF-MIB::ifSpeed.3 = Gauge32: 1000000000
IF-MIB::ifSpeed.4 = Gauge32: 1000000000
IF-MIB::ifSpeed.5 = Gauge32: 1000000000
IF-MIB::ifSpeed.6 = Gauge32: 1000000000
IF-MIB::ifSpeed.7 = Gauge32: 1000000000
IF-MIB::ifSpeed.8 = Gauge32: 1000000000
With OID :
.1.3.6.1.2.1.2.2.1.5.1 = Gauge32: 1000000000
.1.3.6.1.2.1.2.2.1.5.2 = Gauge32: 1000000000
.1.3.6.1.2.1.2.2.1.5.3 = Gauge32: 1000000000
.1.3.6.1.2.1.2.2.1.5.4 = Gauge32: 1000000000
.1.3.6.1.2.1.2.2.1.5.5 = Gauge32: 1000000000
.1.3.6.1.2.1.2.2.1.5.6 = Gauge32: 1000000000
.1.3.6.1.2.1.2.2.1.5.7 = Gauge32: 1000000000
.1.3.6.1.2.1.2.2.1.5.8 = Gauge32: 1000000000
In WebGUI it's not the case (see attached picture).
Am I missing something or is there really a bug in this firmware ?
Thanks for your help.
1 Reply
- CryptageTutor
I've checked on another GS308T switch with 1.4.4 firmware and the problem is the same.
I don't have older firmware to check.
However I've checked on a GS324T switch and this problem doesn't exist.
