sven308's avatar
sven308
SNMP gone since Update GS308T to firmware 1.0.5.7
Hi all,
I updated my GS308T to 1.0.5.7 and since then I cannot do my
   snmpwalk -Os -c public -v 1 192.168.1.99
anymore.
Even cannot add anything in the SNMP menu, comes back with error
"Default private and public community strings are not allowed."
Netgear Documentation did also give no help here.
Any idea, how to get my snmpwalk working again?
Thanks,
Sven
  • Using the default community strings public and private are no longer permitted for security policy reasons. You need to change the read-only and read-write community strings in the switch config and adopt the future snmp queries accordingly.
  • schumaku's avatar
    schumaku
  • ErwinL's avatar
    ErwinL
    NETGEAR Moderator
    Hello sven308,
    And welcome to the NETGEAR Community! 🙂
    Have you tried downgrading the firmware version to what it use to be before and check if that resolves your issue? If it works fine, you may need to open a ticket with Netgear support team if you wish to keep the switch to updated version 1.0.5.7.
    Have a lovely day,
    Logan
    Netgear Team
ProSupport for Business
