marktpalmer
Oct 25, 2017Aspirant
SNMP push Text Config
Is it possible to download a Text Configuration file or a firmware Image to the GS108Tv2 switch using SNMP commands? If so, what are the correct OIDs to use? The target switch I am looking at does ...
- Nov 07, 2017
Hi @marktpalmer,
I have replied to your post here. I have edited and updated the download link with the MIB for the GS108Tv2. You can also download it here.
You may use the NMS300 to download a text configuration file or firmware image. You can download the latest version of NMS300 here.
DaneA
NETGEAR Community Team
marktpalmer
Nov 07, 2017Aspirant
Anyone?
If not possible or unwilling/unable to assist, please provide a link so I can download the GS108Tv2 MIB so I can sort it out myself.
DaneA
Nov 07, 2017NETGEAR Employee Retired
Hi @marktpalmer,
DaneA
- marktpalmerNov 08, 2017Aspirant
NMS is a non-starter (cannot use Windows on our platform).
I have tried to retrieve a file with a known to be working TFTP server, but I get a weird error (its weird because the file I am retireving is the exact file I downloaded via the Web GUI).
The error is "This file is not intended for this product!" (weird right?). I also confirmed I could "download" the file to the switch successfully.
So, it TFTP client broken on the switch?
- DaneANov 09, 2017NETGEAR Employee Retired
Just to verify, are you trying to restore a configuration file to the switch? If yes, what was the firmware version of the GS108Tv2 switch when you have backed up the configuration file?
What is the current firmware version of the GS108Tv2 switch?
Be reminded that if ever you have backed up a configuration file when the GS108Tv2 was using an older firmware version, then you upgraded the firmware of the GS108Tv2 to the latest version, it is not possible to restore the configuration file. You will need to reconfigure the setting from scratch. It is because the configuration file from an older firmware version is not compatible to the latest firmware version.
DaneA
NETGEAR Community Team- marktpalmerNov 09, 2017Aspirant
Am restoring the switch config to the exact same switch. So, no difference in firmware.
