marktpalmer
Oct 25, 2017Aspirant
SNMP push Text Config
Is it possible to download a Text Configuration file or a firmware Image to the GS108Tv2 switch using SNMP commands? If so, what are the correct OIDs to use? The target switch I am looking at does ...
- Nov 07, 2017
Hi @marktpalmer,
I have replied to your post here. I have edited and updated the download link with the MIB for the GS108Tv2. You can also download it here.
You may use the NMS300 to download a text configuration file or firmware image. You can download the latest version of NMS300 here.
DaneA
NETGEAR Community Team
DaneA
Nov 07, 2017NETGEAR Employee Retired
Hi @marktpalmer,
DaneA
marktpalmer
Nov 08, 2017Aspirant
NMS is a non-starter (cannot use Windows on our platform).
I have tried to retrieve a file with a known to be working TFTP server, but I get a weird error (its weird because the file I am retireving is the exact file I downloaded via the Web GUI).
The error is "This file is not intended for this product!" (weird right?). I also confirmed I could "download" the file to the switch successfully.
So, it TFTP client broken on the switch?
