marktpalmer's avatar
marktpalmer
SNMP push Text Config
Is it possible to download a Text Configuration file or a firmware Image to the GS108Tv2 switch using SNMP commands?  If so, what are the correct OIDs to use?  The target switch I am looking at does ...
  • DaneA's avatar
    DaneA
    Nov 07, 2017
    Hi @marktpalmer,
    I have replied to your post here.  I have edited and updated the download link with the MIB for the GS108Tv2.  You can also download it here.
    You may use the NMS300 to download a text configuration file or firmware image.  You can download the latest version of NMS300 here.
    DaneA
    NETGEAR Community Team
ProSupport for Business
