GigaLim
Mar 27, 2024Aspirant
Socket close failed for descriptor error
I'm using the M5300-28GF3 ProSafe 24-port Gigabit Fiber L3, 10-Gigabit product.
However, I would like to know why this error occurs.
Is there any additional information you need?
Wild guess: Your switch is operating as a DHCP client, and fails to get the time interval (option 58) from the DHCP server.
A little bit vague.
Under what conditions and at about which time does this message appear?
Does this message come up in the range of abut 50% of the DHCP lease time renewal?
- GigaLimAspirant
Thank you for your opinion.
This error occurs every minute.
I just checked and the time setting for the switch is not set. It's from 1970.
Is this a problem with incorrect time settings?And there is no other DHCP server setting other than this.
192.168.134.0/24 consists of vlan1 band, which I do not use.
Please give me your opinion
Thank you.
