Aleskpid
Jan 11, 2022Aspirant
Spanning Tree Protocole GS108PE
Hello I would like to connect 3 Switch GS108PEV3 in trunk mode with redundancy. but I can't find the spanning tree protocol is there a way to do this procedure in order to manage the produced loop...
schumaku
Jan 11, 2022Guru - Experienced User
The GS108PE are - like every other Gigabit Ethernet Plus Switches model - not coming with any Spanning Tree support.
Aleskpid
Jan 12, 2022Aspirant
Hello
is there a solution to avoid this loop in the trunk
Sincerely
- schumakuJan 12, 2022Guru - Experienced User
All these switches have a Loop Detection (and pevention) feature -> Gigabit Ethernet Smart Managed Plus Switches User Manual -> Enable Loop Detection p57 ff. It's disabled by default.
- May 25, 2022Retired_Member
