Sajo6000
Mar 26, 2025Aspirant
STP Incompatibility Between Netgear XS708T and MS510TXUP
Hi I'm encountering a peculiar issue while trying to configure LAG (Link Aggregation Group) in my network, and I'm hoping someone here can help me figure it out. I have a mix of Netgear switches: a...
schumaku
Mar 28, 2025Guru - Experienced User
These control selections are to select the policies on how the traffic is distributed on the two or more physical links on a LAG. Every chipset vendor and OEM does typically have different sets available - at the end of the day, a switch with a correct configured and working LAG does not care about. Unrelated to STP - however, STP must sometimes be explicitly configured and enabled on the LAG "device".
