vguna's avatar
vguna
Guide
Oct 22, 2021
Sudden logouts while clicking around in the UI
I recently updated my Netgear switch to 6.0.8.1 firmware and also enabled SSL again. Now I encountered, that I get logged out quite frequently when making configuration changes. It's not like the session timed out due to inactivity, but it happens while I'm navigating through the menus. So e.g. clicking from the top menu, to sub menu, then clicking somewhere else in a row -> logout.
Did someone else encounter this?
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    vguna,
    I suggest you to update the firmware from v6.0.8.1 to v6.0.8.2 then observe if it fixes the problem.  You can download GS752TPv2 firmware v6.0.8.2 here.
    DaneA
    NETGEAR Community Team
    • vguna's avatar
      vguna
      Guide
      I just applied it, I will report back how it goes, thanks!
ProSupport for Business
