bartprokop
Jun 21, 2021Aspirant
Switch enters 802.3af rather than 802.3at mode after restart and fails PoE ports...
Hi, I own GS105PE that I've mounted in attics (where there is no power outlet). The purpose was to power a WiFI AP and also have three usable Ethernet Ports to wire nearby computers. It worked as exp...
- Jun 21, 2021
Thanks schumaku for advice to contact support, it ended with RMA
schumaku
Jun 21, 2021Guru - Experienced User
Not my switch if you don't mind. This is a user community - so it's your switch.
bartprokop wrote:Any power cycling renders PoE PD fifth port to 802.3af (i.e. LED lits orange). .
If the GS105PE does not properly negotiate 802.3at with your Linksys switch PSE on power-up, we face an interop issue of these two devices. As your switch is a new device, you should contact Netgear customer service via https://my.netgear.com/ for assistance. Provide them with the same detailed information (add the AP details for completeness) and include a link to this thread.
The reset button does just trigger a side effect.
bartprokop wrote:When powered by "downgraded 802.3af", it refuses to power up Access Point (the single PoE device connected to port #1).
This is perfectly correct: Because of your Access Point does request more power (802.3af Class 0 or Class 3) then what the switch is able to provide while powered by 802.3af - e.g. only one port can be powered for a Class 1 or Class 2 PD. If a PD does request Class 0 or Class 3 the PD won't get power and can't start. One of many design beauties in these POE industry standards.
