brajeshp's avatar
Jun 24, 2021
WAX610 - 802.3at stopped working
Model: WAX610
After update of firmware (Ver 9.5.1.20) on 18/6, POE+ stopped working and it uses 802.3af only. 802.3at stopped working.
This happened to my two of AP.
  • Finally manage to resolve it.
    1. As per page 225 of switch manual, The power stateful control TLV is defined in IEEE P802.3at D1.0. The later versions no longer support this TLV. HP devices send this type of TLVs only after receiving them.
    2. As per HP knowledge base number emr_na-kc0103319en_us, If the PD is for 802.3at, switch can communicate with the PD using LLDP.
    3. Issue is switch waits for OD (WAX610) to ask for more power however WAX610 waits for switch to give more power. so there is deadlock.
    4. This deadlock can be broken by overloading PD so it request more power from switch. This was the case when I first install WAX610 because I've only one WAX610, later I added another one.
    5. This time after update, there was not enough load. So as per point 2, I enabled LLDP which is not required for a single location. It sets following:
    Power port class : PSE
    PSE power supported : Yes
    PSE power enabled : Yes
    PSE pairs control ability : No
    Power pairs : Signal
    Port power classification : Class 4
    Power Type : Type 2 PSE
    Power Source : Primary
    Power Priority : Critical
    PD requested power value : 25.5(W)
    PSE allocated power value : 25.5(W)
    So problem was solved by enabling LLDP. But it can be solved by loading enough clients on WAX610 too.
    • brajeshp's avatar
      brajeshp
      Tutor
      Hi RaghuHR Raghu,
      Thanks for your reply.
      I'm using HPE 1910-8G-PoE+ (180W) Switch Model JG350A. It's working fine until I upgraded it to latest firmware.
      I've allocated 30w for each AP, however it's drawing only 6-7 watt.
      thanks
      Brajesh
      • RaghuHR's avatar
        RaghuHR
        NETGEAR Expert
        Hi brajeshp
        Send me the screen shot the drawing power from the switch. WAX610 supports at power and no known issue here. Even if you allocate 30W WAX610 may operate at lower level depending the load.It need not draw always the allocated power.
        What was drawing power in the previous firmware?
ProSupport for Business
