langevif
Apr 04, 2017Aspirant
Switch for Stack with 4 SFP+
Hello, I already own a GS728TXS switch wich I use in my server cabinet. I want to build a home lab in an adjacent room and I'm looking for a switch to stack with my GS728TXS. It seems like the new S...
- Apr 18, 2017
I finally did some research and as I understand, I can't stack switch that aren't from the same familiy. So I bought a used GS752TXS on ebay to fullfill my needs.
DaneA
Apr 04, 2017NETGEAR Employee Retired
Hi langevif,
Welcome to the community! :)
You may check either the XS728T or XS748T switches. Both of them have 4 Dedicated 10GBASE-X SFP+ 10G ports supporting 10G/1G speeds. However, it seemed that both XS728T and XS748T switches are not compatible to be stack with the GS728TXS switch.
Kindly check the specifications of the both XS728T and XS748T switches on the data sheet here.
DaneA
NETGEAR Community Team
DaneA
Apr 09, 2017NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed / resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
- langevifApr 18, 2017Aspirant
