MStar-RU
Oct 13, 2021Aspirant
Switch GS110TPv3 + SFP RJ45 adapter
Hello. Please tell me how to activate the SFP adapter in this switch model. It does not want to work without shamanic dances.
schumaku
Oct 13, 2021Guru - Experienced User
Make, model, and configued data (vendor, module type) on your SFP module?
Firmware in place on your GS110TPv3?
According to the GS108Tv3 GS110TPv3 Data Sheet supported modules are:
Optional Modules, Software Licenses and Accessories
AGM731F SFP Transceiver 1000BASE-SX (Short range, multimode)
AGM732F SFP Transceiver 1000BASE-LX (Long range, single mode)
AGM734-10000S SFP Transceiver 1000BASE-T Copper RJ45 GBIC
AXM765 SFP+ Transceiver 10GBASE-T RJ45 GBIC
Shold be straight forward (as you aleady guessed of course).
From Maintenance > Export > HTTP File Export. retrieve the Tech Support file and open a ticket with Netgear Customer Service via https://my.netgear.com/
No indication on the Link/Act LED to the (left?) of the SFP slot?
MStar-RU
Thanks for your time with me.
No indication.
