Generalspace
Jul 01, 2017Aspirant
switch gs116ev2 kicked off internet arris router
Hi All, I have a GS116Ev2 switch that has run great for a year or so. My cable service updated their modem/router (arris) Firmware ver. 9.1.103s5p Now my switch looses its internet connection. The ...
- Jul 19, 2017
OK , problem taken care of it was shentel arris modem/router .The tech. call it an MTA I guess because it had phone in it. Anyway they installed a reg. modem/router and I stayed on the internet. So I bought my own modem and I am using my router. Everything is fine.
, I was sure it was them.
Thanks for the help.
Generalspace
Jul 04, 2017Aspirant
Thanks for getting back to me. The default ip was 192.168.0.239. I enabled DHCP mode and now the ip is 192.168.0.7. I did have a pc lock to that port for a game server. I switch the pc so far everything ok. Is only been a few min. LOL
I will re post in 24 hrs if everything is ok or not.
Thank You
ElaineP
Jul 05, 2017NETGEAR Expert
Hi Generalspace,
You are welcome.
You can do factory default to make the switch have default configuration for every port. Wait for your update for everything.
NETGEAR Employee
- GeneralspaceJul 05, 2017Aspirant
HI,
Ok so is a new day with the same old crap. The internet is down. It worked for a little last night maybe an hour. It was 300am I when to bed. Morning no internet. The network is up I see my nas and other pc's. I did a refresh ip and it show the switch 0.0.0.0. and re did the refresh and it show my pc outside the network. An IP I have not seen .It was not my real ip.
If I unplug the switch from arris modem/router and plug it in another port it works for a short time and gone. It like it shutting off port. I plug a pc right in into modem, the port the switch was on, it dead.
I did look in router setting and i see the the router is set on DHCP is that a problem ? maybe we can set router to lock on switch 192.168.0.239 ?
I have not tried factory defaults , they should be set I basicly have just plug it in and plug in cables. Plug just did new firmware
I skills with network are min. I thank you for your help.
- XavierLLJul 05, 2017NETGEAR Employee Retired
HI GeneralSpace,
About the DHCP, shouldn't be an issue that you have enabled in your router. Could you check under monitoring-port statistics if you can see some errors into the network ports?
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
Hi,
Under monitoring-port statistic no errors. I did do the factory default same problem. Here what i did and so far I am up. I put my 4 port hub in between the router and the switch so far I am still on line, its been an hour.
I do get this message when i use the utility Error-there is a commumication problem access netgear registion server. registration process is cancelled. Please check your internet connection and regist the product next time
