Martdor
May 15, 2023Tutor
Switch GS308EP - POE led blinking slow
Dear all, Last week, I bought the #300 Series SOHO Plus (GS308EP) switch. I can access and set up the switch via my computer. However, when I connect a POE device (IEEE 802.3af), the POE LED sta...
- May 17, 2023
It was an error in my PCB. Sorry for the inconvenience. The PCB was consuming too much current...
Martdor
May 16, 2023Tutor
Hello AnishaA,
Thanks for the welcome!
I have connected the POE device to port 2. Which the following settings:
The device is a custom made PCB which include the Onsemi NCP1091 PoE-PD Interface Controller.
The basic LED status for the right port LED does not say anything about slow flashing. What could this mean?
schumaku
May 16, 2023Guru - Experienced User
Hard to say, any kind of error is possible. Power loop, short circuit, wrong ground e.g. of data wires, ...
not that you don't have it, just for reference: NCP1090 - Integrated IEEE 802.3af PoE-PD Interface Controller (NCP1090, NCP1091, NCP1092)
