AlessandroP7
Sep 04, 2025Follower
Switch GS752TPP rules ACLs creation problem
Hello,
I'm having trouble assigning an ACL rule to the switch ports
and I can't figure out what's missing in the configuration I'm trying to set up.
The switch primarily serves an office (the switch is connected to the main one via a truck on two ports) where I have the same VLAN 20 on 45 ports.
For that VLAN, I created an IP ACL with 11 sequences.
My intention is to apply it to the ports with that VLAN, so in the "IP Binding Configuration" section, I selected ACL ID and started checking the relevant ports, but I can't get past 29 ports out of the 45 I should theoretically reach. How can I resolve this and configure it correctly so that the rules are applied to all ports affected by VLAN 20?
I'm probably using the wrong approach. Can someone clarify?
Thank you.
1 Reply
The number of ACL entries by ACL rule is limited - that's why you can't add more to the ACL #120.Consider creating and maintaining multiple ACL rules instead.
No idea why people are hiding simple RFC1918 IP addresses in the screenshots, there is no need to - these address ranges are known worldwide, are the same, ...
