doctor15's avatar
doctor15
Switch shows wrong Firmware
I bought a used JGS516PE.  Plugged it in and all worked fine.  Outisde looks like the typical picktures I see of JGS516PE and show that model number both on the front and sticker on the bottom.
However when I login to the switch, the firmware shows "GS108Ev3" and I can only see 8 of 16 ports.  I know only 8 ports or POE, but I assume I should be able to apply VLAN settings to all 16 ports?
I tried installing the correct firmware via HTTP Web UI, but I get a message "Firmware is invalid".
Any idea how this might have happened and if it can be salvaged?  Are there alternative ways to force a firmware update?
See below image of what I currently see when I login to Web UI
Firmware
  • So this is embarresing but turns out I had a 2nd ProSafe switch on my network that I didn't realize was managed / web accessible, and was accidentally connecting to that model instead.
    Please delete / ignore this topic
1 Reply
No content to show
ProSupport for Business
