fireline's avatar
fireline
Follower
Nov 22, 2021
switch status config mismatch
Added a switch to our reconfigured stack
the switch that used to be in position 4 was an s3300 28x
The one in that position now is an s3300 52x
the stack is reporting a config mismatch
It shows that the preconfigured model identifier is a 28x and the attached is a 52x
How do I rectify this?
1 Reply
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    fireline,
    Welcome to our community! :)
    Please make sure that the firmware version of the switch that you are trying to add has the same firmware from the switch on the stack. You may also try to reboot all the switches to re-elect the master.
    John
    NETGEAR Community Team
ProSupport for Business
