GaACETech
Feb 09, 2021Guide
Switch VLAN issue
Using 16 port Netgear Switch GS716T (version 3 i believe) Port 1 cabled to Router Port 2 cabled to Access Point Port 3-16 client devices Switch has default VLAN 1 Access point guest traffic g...
schumaku
Feb 10, 2021Guru - Experienced User
Does the router support multiple networks, is the router port configured for the additional tagged VLAN, is there a dedicated IP subnet configured on this additional network, and last but not least is there DHCP service active for the additional network?
GaACETech
Feb 10, 2021Guide
schumaku wrote:Does the router support multiple networks - yes, (router is a Sonicwall TZ350)
is the router port configured for the additional tagged VLAN - yes, (guest network is configured with a guest IP network)
is there a dedicated IP subnet configured on this additional network- yes,
and last but not least is there DHCP service active for the additional network - yes (DHCP service is checked for the subnet)
I just checked all of these and they appear to be set correctly.
so there is not a need for the VID configuration to set these 2 ports to vlan 10? again the 2 ports are the internet connection to the switch and the AP port on the switch).
Thanks!
Darryl
- schumakuFeb 10, 2021Guru - Experienced User
Both the port to the router and the AP need to have this VLAN 10 added as tagged. Check the Sonicwall config for proper tagging on the same port.
