burgdoas
Jul 14, 2026Aspirant
Switches indicate receiving signal, not detecting devices
I have had a GS316EP for 4 years. It was used to power 2 PoE cameras and for my home office. About a month ago, it stopped working. When I plug the Cat 5e from the router into each port, they light u...
schumaku
Jul 15, 2026Guru - Experienced User
Factory reset (default) the GS316EP, ensure the correct power supply is plugged.
Are the connected devices in question PoE powered?
Do non-PoE Ethernet devices connected show both Link and activity?
The GS316EP is about a 200 W capable unit, 54V, delivering up to about 3.7 A, best guess, the GS316PP power supply is the very similar 200 W unit, 54V, 3.7A.
burgdoas wrote:Switches indicate receiving signal
So what signals are you talking about please?
- StephenBJul 15, 2026Guru - Experienced User
That's what I think too. But I am wondering if the original power brick is failing
- burgdoasJul 16, 2026Aspirant
I have tried the power brick for the original switch and the replacement switch, both of which provide the same capacity and are meant for PoE switches. The other switch is just unmanaged (also has the same issues).
Power supply is the factory power supply that came with the switch. The indicators that I can see are the Power LED and the Left Port LED for the port coming from the router. There are no other LEDs lighting up and none of my other devices are receiving internet or power from the switch.
There are two PoE camera which are not receiving power or internet and my PC, which is not getting internet signal either.
- StephenBJul 16, 2026Guru - Experienced User
Just to clarify this - are you saying that you used the GS3116PP"s power adapter when you installed the GS3116PP?
Yes, I did.
- schumakuJul 17, 2026Guru - Experienced User
Tastes like either the two PoE all other Ethernet connected devices are defective (extreme unlikely, isn't it?) - or this GS316PP is DoA (uncommon, but happens).
As a test, try the power supply of the previous GS316EP on the GS316PP, as all supplies the same voltage. For just the switch operations and supplying PoE to just two 802.3af or 802.3at PD, this seems sufficient.
Factory reset did not fix the problem.
The only device indicating that is connected and active is the router. No other devices have any indication of activity.
