burgdoas
Jul 14, 2026Aspirant
Switches indicate receiving signal, not detecting devices
I have had a GS316EP for 4 years. It was used to power 2 PoE cameras and for my home office. About a month ago, it stopped working. When I plug the Cat 5e from the router into each port, they light u...
Jul 15, 2026Guru - Experienced User
schumaku wrote:The GS316EP is about a 200 W capable unit, 54V, delivering up to about 3.7 A, best guess, the GS316PP power supply is the very similar 200 W unit, 54V, 3.7A.
That's what I think too. But I am wondering if the original power brick is failing
burgdoas
Jul 16, 2026Aspirant
I have tried the power brick for the original switch and the replacement switch, both of which provide the same capacity and are meant for PoE switches. The other switch is just unmanaged (also has the same issues).
