burgdoas
Jul 14, 2026Aspirant
Switches indicate receiving signal, not detecting devices
I have had a GS316EP for 4 years. It was used to power 2 PoE cameras and for my home office. About a month ago, it stopped working. When I plug the Cat 5e from the router into each port, they light u...
schumaku
Jul 15, 2026Guru - Experienced User
Factory reset (default) the GS316EP, ensure the correct power supply is plugged.
Are the connected devices in question PoE powered?
Do non-PoE Ethernet devices connected show both Link and activity?
The GS316EP is about a 200 W capable unit, 54V, delivering up to about 3.7 A, best guess, the GS316PP power supply is the very similar 200 W unit, 54V, 3.7A.
burgdoas wrote:Switches indicate receiving signal
So what signals are you talking about please?
burgdoas
Jul 16, 2026Aspirant
Factory reset did not fix the problem.
The only device indicating that is connected and active is the router. No other devices have any indication of activity.
