burgdoas
Jul 14, 2026Aspirant
Switches indicate receiving signal, not detecting devices
I have had a GS316EP for 4 years. It was used to power 2 PoE cameras and for my home office. About a month ago, it stopped working. When I plug the Cat 5e from the router into each port, they light u...
burgdoas
Jul 16, 2026Aspirant
Power supply is the factory power supply that came with the switch. The indicators that I can see are the Power LED and the Left Port LED for the port coming from the router. There are no other LEDs lighting up and none of my other devices are receiving internet or power from the switch.
There are two PoE camera which are not receiving power or internet and my PC, which is not getting internet signal either.
schumaku
Jul 17, 2026Guru - Experienced User
Tastes like either the two PoE all other Ethernet connected devices are defective (extreme unlikely, isn't it?) - or this GS316PP is DoA (uncommon, but happens).
As a test, try the power supply of the previous GS316EP on the GS316PP, as all supplies the same voltage. For just the switch operations and supplying PoE to just two 802.3af or 802.3at PD, this seems sufficient.
