SubX
Dec 14, 2017Aspirant
Switching from Cisco SG200 to GS724T, Need help on Trunk, Access mode equellent in NetGear
Switching from Cisco world to NetGear. Need help on some of the basic
In Cisco I have the following 3 types of port/VLAN mapping, how should I have a similar setup in NetGear?
1 - Port1 (Trunk port) - 8T,18T,88T,100T, 1U (PVID = 1)
2 - Port 6 (Access port) - 88U (PVID = 88)
3 - Port 8 (Trunk Port) - 1U (PVID=1)
NetGrear term
Admit All - does it mean Trunk Port in Cisco term
VLAN only - does it mean Trunk Port in Cisco term and only tagged VLAN allowed?
how to setup Access port (Cisco term) in NetGear?
Thanks a lot!
Sub
Hi SubX
In order to make an access port on a Netgear switch, you untag (U) that VLAN and set a PVID on the port.
In order to Trunk a VLAN, you tag that VLAN (T) on the port.Example:
I want port 1 to be an access port for VLAN 10
I want port 2 to be an access port for VLAN 20
I want port 24 to be the uplink and trunk both VLANs across to the next switch/routerConfig:
Port 1 = Untag (U) for VLAN 10 and set PVID of 10.
Port 2 = Untag (U) for VLAN 20 and set PVID of 20.
Port 24 = Tag (T) for both VLAN 10 and 20.Your questions about Acceptable Frame Types (Admit all/VLAN only) refers to whether the switch should only you accept frames with a VLAN tag on or accept all frames. You don't need to worry too much about this, unless you have a specific need/security requirement. Leave it at Admit all and you'll generally be fine.
Here is an article that might be helpful.
https://kb.netgear.com/11673/How-do-I-setup-a-VLAN-trunk-link-between-two-NETGEAR-switchesCheers
- HopchenProdigy
Hi SubX
- SubXAspirant
Thanks for a detail and structural response.
With your help, I got it working.
Cheers,
Sub
- HopchenProdigy
Hi again,
No problem at all. Happy to help.
It is worth mentioning that this way of managing your VLAN config is referred to as "General Mode". On Netgear fully managed switches, you also have the option to configure VLANs via the Access/Trunk Mode (as you are used to). It all accomplishes the same result, but it's a preference on which mode people want to use. On smart switches (such as the one you have), you only have the "General Mode" way of configuring the VLANs.
Cheers!
