rossbaynham
Jan 17, 2023Aspirant
Synology Server - Netgear GS308E Switch - Ubiquiti Access Point
Hi guys, I am not an IT expert so please bear with me! I am trying to set up a Synology server in my office, which will be plugged into four iMac computers using a Netgear Switch (GS308E). ...
Jan 17, 2023Guru - Experienced User
That small white box (usually) is the power injector for the access point.
So it should go ethernet cable from wall---->switch----->to power injector----->to access point
with your other devices connected to the switch.
That ensures the power from the injector is supplying the AP.
- rossbaynhamJan 17, 2023Aspirant
Thanks a lot - that's really helpful to know!
Cheers
Ross
