NightHawks_2021
Jun 17, 2021Initiate
syslog on the GS108Tv3
Hell community,
I am running the GS108Tv3 Netgear 8 port managed pro switch.
I am currently on Software version 7.0.7.1. I recently upgrade as the previous version I was on 7.0.0.x I believe.
In this new version, this switch sends syslog messges incorrectly breaking my parser.
As you can see below, the format is incorrect and its appending a "-1" to the IP address for some reason. This did not occur with the older softrware version. Is anyone aware of the problem or at least know how to get in touch with tech support to see if there is a fix?
syslog-ng[1544091]: Error processing log message: <14>1 2021-06-17T23:34:08.58>@<0-4:59Z: %192.168.50.180-1
- NightHawks_2021Initiate
Thats a good idea. Other partition is available with the earlier code. Thanks.
