siletzspey's avatar
siletzspey
The handling of untagged packets across a physical network
I should be getting two GS308T units tomorrow.   Glancing at this forum and the owners manual, I feeling mystified about the handling of untagged packets, and the notion of packets "defaulting to V...
  • schumaku's avatar
    schumaku
    Jan 06, 2021
    Thats the ah-haa I wanted to happen!
    On a switch, and by design you have one or multiple VLAN on a physical network.
    On the links, e.g. a Ethernet link, a LAG, ... a VLAN can be tagged (one or many), or untaged. A port where you want to connect a system for VLAN 123, is only an untagged member of VLAN 123, the PVID 123 does make untagged frames to enter the VLAN 123. The traffic in a VLAN is not VLAN "tagged" - while this is not fully correct,also QoS information can be part of a tag. How the frames are coming out of a port, with or without VLAN tags, is defined at the switch boundary. Where untagged frames are assigned to does also happen as defined by the PVID at the switch boundary.
    Similar for the wireless access point - there the VLAN is always* untagged on the SSID. (*Again, highly sophisticated designs allow one SSID and multiple VLANs, depending on the 802.1x authentication the VLAN membership can be assigned).
ProSupport for Business
