AresSky
May 22, 2026Follower
The password for the GS752TP switch is los
Good day. Since 2021, the GS752TP switch has been installed - at the moment there is a need to change the configuration, but the password has been safely forgotten by everyone, including the old ...
schumaku
May 22, 2026Guru - Experienced User
While the Netgear (fully) Managed Switches - where you initially posted your question (a moderator will move it to the more appropriate community section -> Easy Smart, Plus and Smart Switches) - are coming with a serial and/or USB-based console port have an option for breaking the boot process and set a new password (->
[KB 67268] How do I recover the password using the boot menu on a M4250 series or M4350 series fully managed switch ) there is to my knowledge no boot menu available to make this happen on the Smart Switch models like your GS752TP.
