David288
Nov 16, 2016Aspirant
Can not access stackable GS752TPS switches web interface
I have 3 GS752TPS stacking
No1 port 51 connect to No2 port 52
No2 port 51 connect to No3 port 52
No3 port 51 connect back to No1 port 52 (self healing)
I can see the GS752TPS IP in SmartControlCenter, but when I try access web interface, get msg "Unable to connect"
Any ideas?
Thanks!
Hi David288,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
- JohnRoNETGEAR Employee Retired
Hello David288,
Welcome to the community!
Let me see if I can help you out. Did you make any changes on the stack prior to experiencing the issue? Are you able to ping the switch? Have you tried rebooting the stack?
Thanks,
- David288Aspirant
We have reboot the switches but still can't access the web interface.
The only thing we did was add the 3rd unit.
Can u tell us the correct way to link up the 3 GS752TPS switches?
