tempaccount
Jan 19, 2018Tutor
Thread not showing up / 404 without login
Hi, few weeks ago i've created the following thread: https://community.netgear.com/t5/Smart-Plus-Click-Switches/Bug-on-cable-test-quot-Short-Circuit-quot/td-p/1452727 When opening the link w...
- Jan 28, 2018
You may create a new post instead. Also, I checked with NETGEAR Support about your online case and found out that it is to be escalated to the higher tier of NETGEAR Support for as long as you complete the details needed for escalation. These details are needed for further investigation of the engineering team.
For me, if ever you create a new post with regard to your concern, I suggest you to still continue with your online case with NETGEAR Support. It is because there will be a time that all of the troubleshooting steps suggested here in the community would be all exhausted and in the end you will be recommended to contact NETGEAR Support.
DaneA
NETGEAR Community Team
schumaku
Jan 22, 2018Guru - Experienced User
DaneA ...if a post is moved to the more appropriae forum arey, like from "Managed Switches" to "Smart / Plus / Click Switches", is the old URL retained with a http code 301 or 302?
DaneA
Jan 22, 2018NETGEAR Employee Retired
I am not familiar about the http code you are referring to. I have moved a forum thread just a while ago and the link has changed which indicates that it has been moved to the appropriate community board.
Example:
From the example above, notice that the part that says 'Managed Switches' on the link was changed to 'Smart-Plus-Click-Switches.'
DaneA
