GuyTrem
May 21, 2025Aspirant
Time to renew my GS716T v3
Hi all I have a GS716T v3 which is the main switch in my home. I got it 2nd hand about 5 years ago, so it will be older than that now. I think it is time to replace with an up to date Poe switch....
May 21, 2025Guru - Experienced User
Are you using much for features on it? If not, why upgrade if you're only going gigabit? If you're not doing much for traffic analysis, the 716 still works fine. I'm using one in my media room with a unmanaged 2.5gig switch for those devices that are multigig. They can be picked up pretty cheap from a across the pond sites.
GuyTrem
Hi ,
yes it still works fine...just a bit worried about the age of it. I would also like POE .
