Mi7ooo's avatar
Mi7ooo
Tutor
Jun 10, 2024
Re: DHCP constantly renewing XR500
Hi all,
I also started getting the same dhcp lease renewal issue. Im using version 134. I have been using it for years but the past few weeks the router started having this issue.
I tried setting up the max dhcp value to 100 and also reserved ips for my devices. It worked for a week and started again.
Please help
  • Mi7ooo's avatar
    Mi7ooo
    Jun 19, 2024
    Hi Fraser,
    Yes i did that and the router seem to be working fine for now. I flashed version 114 using tftp, did factory rest and then upgraded to 134.
    Thanks for the usual support.
    MJ
  • FURRYe38's avatar
    Try setting DHCP range from .100 to .200?
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    • Mi7ooo's avatar
      Mi7ooo
      Tutor
      Hi,
      I tried the suggested solution, but the issue persists. The router stayed fine for a couple of days though
      My modem is huawei hg8245w5.
      I dont remember if i have done mf reset on the firmware.
      Any tips ?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Disable DHCP entirely (make sure you've reserved all the IPs) and then it should be better
