GuyTrem
May 21, 2025Aspirant
Time to renew my GS716T v3
Hi all I have a GS716T v3 which is the main switch in my home. I got it 2nd hand about 5 years ago, so it will be older than that now. I think it is time to replace with an up to date Poe switch....
May 21, 2025Guru - Experienced User
Do you need managed? If unmanaged is fine, you can still get multigig, unmanaged, and poe for a reasonable price
