RNUK
Dec 14, 2020Aspirant
Tuya / Lidl smart home devices don't work when connected to GS724Tv4
Hi All, Got a strange one here.... bought a Lidl smart home device and connected it via my switch. It's a rebadged Tuya device. When I search for the gateway, it eventually finds it, but it can...
Dec 14, 2020Guru - Experienced User
for some, double nat's doing cause issues.
others its nothing but issues. If its working and working fine, i'd leave it.
What Tuya devices is it?
RNUK
Dec 16, 2020Aspirant
plemans wrote:for some, double nat's doing cause issues.
https://www.lidl.co.uk/our-products/smart-home (Picture 2). Lidl just rebadge them.
schumaku wrote:Assume the PHY link on the port speed makes sense (same speed as on the Asus), the device does get an IP address assigned by DHCP (check the Asus router DHCP table/connected devices), check the switch ARP table for the device MAC address, ... have an eye for the IGMP Multicast settings for the VLAN in use. Allow IGMP multicast, and don't block unknown multicast.
The device is 100mbps. Asus is 1000mbps. Device gets assigned an address. Fing on my phone can find it.
Switching / Address table shows the device connected
I followed this to confgure IGMP Multicast
https://support.biamp.com/Tesira/AVB/Configuring_IGMP_Snooping_on_the_Netgear_GS724Tv4
Still not working.
Block Unknown is disabled.
- schumakuDec 16, 2020Guru - Experienced User
Looks like I have to drive to Lidl these days and buy such a monster 8-/
- schumakuDec 19, 2020Guru - Experienced User
CAncel the my idea that it's MDNS based - much more the discovery is using the classic IoT UDP IPv4 broadcast, source port 41457, destination 6667.
- RNUKDec 19, 2020AspirantOK. Sounds like you're closer. What do I need to tweak to get it working when it's connected to the switch?
