AS510
May 24, 2021Follower
Unable to configure VLAN for Netgear GS728TPv2
Hi all, networking newbie here and I was trying to configure a VLAN for the Netgear GS728TP switch for my company. I followed all the instructions here:
https://kb.netgear.com/31026/How-to-configure-a-VLAN-on-a-NETGEAR-managed-switch
I created a new VLAN, chose the correct ports to be added, removed the chosen ports from the default network and configured the PVID to match the VLAN. I have attached some screenshots to hopefully better illustrate my situation. Is there something I need to do on the VLAN section of the routing tab? VLAN ID is 10. Thanks for all your help in advance!
1 Reply
Looks fine, your new VLAN 10 is an isolated network on the two ports (11 and 12) selected.
What is the issue, why do you think this does not work accordingly? Any other expectations?
