keonluke
Jan 30, 2021Follower
unable to connect to m5300v11.0
good morning
so i am use to working with the gs728tpp and gs516tp. i got a m5300-52g switch and i am having some trouble connecting to it.
usually i would pugin a dhcp device to the switch find the ip and connect using a web browser. but this switch is either not taking the ip or isnt allowing me to see its ip address.. can anyone advise on the connection method of this model.
1 Reply
- DaneANETGEAR Employee Retired
Is this an initial setup of your M5300-25G switch? If yes, kindly try to access it via console connection and from there you can assign a static IP Address using CLI commands. Afterwards, you can access the switch web-GUI using the static IP Address you've assigned.
Kindly access the links below as these might help you:
M5300 CLI Command Reference Manual Software Version 11.0.0
DaneA
NETGEAR Community Team
