peterwbaker1100
Aug 24, 2020Tutor
Unable to establish 802.3ad Dynamic Link between Synology DS918+ and Netgear GS324T Pro Switch
Swapped out my trusty Cisco SG200-8 for a Netgear GS324T and it all went smoothly! However, I have been unable to re-establish the 802.3ad Dynamic Link between my Synology DS918+ and the Netgear GS3...
- Sep 03, 2020
First of all “hats off” to Netgear for offering 90 days free support with such a reasonable price switch as the GS324T, had a very useful conversation with them that later led me to the solution! I had not noticed before the DS was going “off air” as soon as I configured the LAG, I’d only notice it was gone after I configured 802.3ad on Synology DSM!
Updated the firmware from V1.0.0.27 to V1.0.0.30, No change in behaviour…
The following worked, at least for me!
Set the GS324T LAG with:
- Hash Mode set to “6. Src/Dest IP and TCP/UDP Port Fields” (default is 3)
- Leave LAG Type as “Static” (default)
- Set “LACP System Priority” to 1 (default is 65535)
Enable 802.3ad network connection in the DS (DSM reports back “Failed to establish IEEE 802.3ad connection”. In red!).
Change the GS324T LAG Type to “LACP”
Return to the DS to find it has established the IEEE 802.3ad connection.
Rebooted everything just to make sure it was not a fluke and for now all is good!
Hope that helps someone else… Peter
peterwbaker1100
Aug 24, 2020Tutor
In a 10 seconds check, the LACP LAG config looks OK as far it's visible. <<<Thanks for looking:-)
Both GbE links are coming up, the link LEDs become active? <<< Yes, green lights on Switch and both ports show "active" on the switch web interface and the DS918+, in fact it all works fine I am just trying to get the 802.3ad group working so when my home backups kick off it can use the full 2GB capacity.
Plugged the ports configured to the LAG? The UI an be confusing because it does show RJ45s for all ports. <<<Yes that is a bit confusing but ports 23 & 24 are the ones configure & connected. See attached image.
Something is happening as after try to apply the 802.3ad configuration on the DS918 it fails and then "dissappears" from the network and only way I can get it back is to remove ports 23 & 24 from the LAG configuration and then the DS will revert back to a working Adaptive Load Balancing connection... It is as if the DS trying to establish connection with the Switch is confusing it!
Regards, Peter
schumaku
Aug 24, 2020Guru - Experienced User
Try to configure the LAG with just one port (might have to edit the Syno config manually). This will leave you a backdoor on the second interface just in case to check from the N AS Linux console, e..g (taken from a QNAP, similar on all Linux systems):
[~] # cat /proc/net/bonding/bond*
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
Bonding Mode: IEEE 802.3ad Dynamic link aggregation
Transmit Hash Policy: layer2+3 (2)
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 0
Down Delay (ms): 0
802.3ad info
LACP rate: slow
Min links: 0
Aggregator selection policy (ad_select): stable
System priority: 65535
System MAC address: <snip>
Active Aggregator Info:
Aggregator ID: 4
Number of ports: 4
Actor Key: 9
Partner Key: 1000
Partner Mac Address: 10:da:43:<snip>
Slave Interface: eth0
MII Status: up
Speed: 1000 Mbps
Duplex: full
Link Failure Count: 0
Permanent HW addr: <snip>
Slave queue ID: 0
Aggregator ID: 4
Actor Churn State: none
Partner Churn State: none
Actor Churned Count: 0
Partner Churned Count: 0
details actor lacp pdu:
system priority: 65535
system mac address: <snip>
port key: 9
port priority: 255
port number: 1
port state: 61
details partner lacp pdu:
system priority: 32768
oper key: 1000
port priority: 128
port number: 1
port state: 61
- peterwbaker1100Aug 25, 2020Tutor
Thanks for the advice @schumaku I'm sad to say that level of technical DSM knowledge is above my technical pay grade:-) I would probably do more damage than good trying to do it. Best Regards, Peter
- peterwbaker1100Sep 03, 2020Tutor
- schumakuSep 03, 2020Guru - Experienced User
Great you have it resolved.
FWIW, the only item which can have an impact on establishing the dynamic 802.3ad LACP LAG is the System Priority.
