coxbuell's avatar
Jul 19, 2017
Switchs compliant 802.3ad network (incuding LACP)
Hi,
I would like to change our network to be compatible with Qnap NAS setting aggregation port which asks 802.3ad protocol.
I actually have the following switch material (behind a ISP router):
1 x GS116E
2 x GS108
4 x GS105
I need to upgrade with 802.3ad compliant material (incuding LACP).
Which material can you suggest to me?
Thanks for your help.
Best regards,
NC
  • Hi coxbuell,
    It seems that you need LACP in order to work with your Qnap NAS. Smart Switches does support LACP or 802.3ad protocol.
    You may check the list of our smart switches here.
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi coxbuell,
    • coxbuell's avatar
      coxbuell
      Tutor
      Thanks.
      I will check for smart switchs.
      Best regards.
      NC
      • JohnC_V's avatar
        JohnC_V
        coxbuell,
        I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
