coxbuell's avatar
Jul 19, 2017
Switchs compliant 802.3ad network (incuding LACP)
Hi, I would like to change our network to be compatible with Qnap NAS setting aggregation port which asks 802.3ad protocol. I actually have the following switch material (behind a ISP router): 1 x...
  • JohnC_V's avatar
    Jul 20, 2017
    Hi coxbuell,
    It seems that you need LACP in order to work with your Qnap NAS. Smart Switches does support LACP or 802.3ad protocol.
    You may check the list of our smart switches here.
ProSupport for Business
