coxbuell
Jul 19, 2017Tutor
Switchs compliant 802.3ad network (incuding LACP)
Hi, I would like to change our network to be compatible with Qnap NAS setting aggregation port which asks 802.3ad protocol. I actually have the following switch material (behind a ISP router): 1 x...
JohnC_V
Jul 20, 2017NETGEAR Employee Retired
Hi coxbuell,
It seems that you need LACP in order to work with your Qnap NAS. Smart Switches does support LACP or 802.3ad protocol.
You may check the list of our smart switches here.
coxbuell
Jul 20, 2017Tutor
Thanks.
I will check for smart switchs.
Thanks for your help.
Best regards.
NC
- JohnC_VJul 20, 2017NETGEAR Employee Retired
I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- coxbuellJul 24, 2017Tutor
Hi,
Accepted solution.
Thanks.
NC
