KirbyKB
Feb 06, 2025Aspirant
Unable to set SFP+ port to 10Gb negotiation on MS510TX
Hi, Since the peer device only support manual link speed. Is there any way to configue the MS510TX switch to 10Gb? Thanks,
- Feb 07, 2025
Found that is peer SFP module issue, case closed
schumaku
Feb 06, 2025Guru - Experienced User
No, and it's not required.
Are we facing fiber or copper SFP+ modules here?
On Ethernet copper links, IEEE clearly requires (mandtory) that the link speed -must- be negotiated for link speeds from 1000M and up (faster).
On fiber links there is -no- link speed negotiation, the default speed is used. So the only exception you might have to worry are 10G fiber modules, but you need a 1G link only. The solution is -not- using a 10G module, but install a 1G module instead.
Does this cause an issue, or is this some (likely outdated) idea or assumption that you "have" to define the link speed?
