sebbe
Dec 01, 2021Aspirant
Unreliable cold boot XS712T
I bought a used XS712T for about 200euro, and I have problems booting it up from cold. The pattern I describe below has made itself apperant over many days of testing. Netgear do not honor their Lif...
JohnC_V
Dec 07, 2021NETGEAR Employee Retired
Welcome to our community! :)
We do apologize for the experience that you had with our switch. We do not recommend purchasing 2nd hand products because this will void the warranty of the switch. We are also not sure if the product that you purchased is already modified with a different firmware or not.
You may check our warranty policy here.
John
NETGEAR Community Team
sebbe
Dec 07, 2021Aspirant
FYI the firmware is on latest revision.
FYI I have bought used hardware from dell, hp and others, updated their firmwares and have had zero problems. This is the first used device I purchase that has been of subpar quality.
